engine cant start, when driving its gutless
2006 FORD EVEREST
140,000 MILES
MONISH
even after driving when the engine is still hot, it cant start. the speed pedal is pressed fully to the floor but the car is not driving as expected. on the hills it give ups. the car is not giving any black smoke. the temperature gauge is normal goes only till the half mark but within short distance. after consulting the mechanic he said that it may be the fuel pump but he was not sure, if needed be then i will change the engine because there is no other problem related to it.
Oct 28, 2013 at 8:21 AM
HMAC300
  • 48,601 POSTS
we have no info n these but scan for codes and check fuelpressure with a gauge the mechanic is probably right but you ned to know if it' s low pressure you can fix the pump by replacing it.
Oct 29, 2013 at 12:40 AM
