Engine camshaft position sensors, code P0012
76,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
GDMBROWN
What side is Bank 1? I had a code P0012 camshaft position sensor intake bank 1 over retarded.
Sep 8, 2020 at 2:11 AM
Good evening,
I attached the procedure for you of the removal of the sensor. The passenger side of the engine is bank 1.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
It is very tight to get back there to the sensors.
Camshaft Position (CMP) Sensor
Materials
Name Specification
Motorcraft® SAE 5W-20 Synthetic Blend Motor Oil
XO-5W20-QSP WSS-M2C945-A
Removal
NOTE: Removal steps in this procedure may contain installation details.
RH (right-hand) Camshaft Position (CMP) Sensors
Remove the RH fender splash shield.
Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation) .
Disconnect the intake CMP sensor electrical connector and remove the retainer and the CMP sensor.
Material : Motorcraft® SAE 5W-20 Synthetic Blend Motor Oil / XO-5W20-QSP (WSS-M2C945-A)
Torque : 89 lb.in (10 Nm)
Disconnect the exhaust CMP sensor electrical connector and remove the retainer and the CMP sensor.
LH (left-hand) Camshaft Position (CMP) Sensors
Remove the LH fender splash shield.
Position aside the radio ignition interference capacitor.
Installation
Note: Before installation, lubricate the CMP sensor O-ring seal with clean engine oil.
To install, reverse the removal procedure.
Dec 8, 2020 at 8:16 AM
  • 110,248 POSTS
From the front of the vehicle facing the engine, it will be on your left. I attached a pic below showing location. You are focused on bank 1 sensor 1.
2017 Ford Truck F 150 4WD V8-5.0L
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Camshaft Position Sensor Service and Repair Removal and Replacement Camshaft Position (CMP) Sensor
CAMSHAFT POSITION (CMP) SENSOR
Materials See pic 2
Pic 3
Pic 4
Install is the reverse of removal.
__________________________
Dec 8, 2020 at 8:18 AM
