engine bogging down when turbo kicks in
96,000 MILES • 3.7L • 6 CYL • TURBO • 2WD • MANUAL
DJCARLALLEN
i recently changed my exhaust manifold and turbo (ct26) since the change the drives fine until you step on it and the turbo kicks in it bogs down like not enough gas once i ease off it drives normal i can achieve hiway speeds and better but not while turbo is engaged help
Sep 14, 2014 at 12:20 PM
HMAC300
  • 48,601 POSTS
wa it the same size turbo or larger you may need to richen fuel up. scan for codes first though
Sep 15, 2014 at 12:17 AM
