I checked the fuel pressure it is at 60 and I had the car scanned, got codes for the mass air flow sensor, thermostat, and two for the catalytic converter.
Apr 27, 2016 at 9:25 AM
JEANNIE JACKSON
MEMBER
I replaced the mass airflow sensor and it is still bogging.
Apr 27, 2016 at 9:33 AM
HMAC300
✓Experienced Mechanic
then you will have to try to disconnect converter and see if that fixes it. if you got the 420 code your converter is probably plugged.if you can check intake vacuum at idle if 15" or below it is probably a plugged exhaust auto parts may rent that or check it for you as well.
