Engine blown
165,000 MILES • V6 • 2WD • AUTOMATIC
MEG LEIGH
I had the water pump replaced and a day later driving, the engine went out loudly. Was it the tensioner? Did the guy doing the water pump not do something right?
Aug 24, 2019 at 8:15 AM
Hi Meg,
Clearly anything is possible but there are things as coincidences. If you suspect the previous mechanic caused it, I would suggest you take it to another mechanic and tell them what happened and that you want everything documented as they take it apart to try to and verify if they did anything wrong.
Unfortunately, there is no way to know for sure based on this information. On the surface I would think it is suspicious at best so if you don't trust this mechanic, I would have another try to identify exactly what caused the engine to fail and then you can go to the next step and approach the other shop.
Let me know if there is any other way I can assist. Thanks
Aug 24, 2019 at 9:48 AM
