Engine block serial number
17,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
2018GRANDCARAVAN
  • 7 POSTS
In what places can I find the engine serial number?
What does decoded number mean?
Oct 3, 2018 at 12:26 AM
  • 55,691 POSTS
It is usually stamped on the front of the block where the cylinder heads are bolted on. What problem are you having? Not sure what you mean by decoded number?
Oct 4, 2018 at 4:47 AM
2018GRANDCARAVAN
  • 7 POSTS
Front of block on a Pentastar V6 ?
Need to determine date of manufacture.
Oct 4, 2018 at 7:13 AM
  • 55,691 POSTS
I called the dealer they said is was on left side of engine down by the starter on a stamp or there is a barcode and a number under the code which will be on the valve cover which will be the serial number.
Oct 6, 2018 at 4:36 AM
2018GRANDCARAVAN
  • 7 POSTS
What does each letter or number mean?
Oct 7, 2018 at 4:00 AM
  • 55,691 POSTS
You would need to call the dealer for that.
Oct 8, 2018 at 2:46 AM
2018GRANDCARAVAN
  • 7 POSTS
Oct 8, 2018 at 3:25 AM
  • 55,691 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Oct 9, 2018 at 5:10 AM
