Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Block
Engine block
2003 DODGE CARAVAN
150,000 MILES
TIMOTHY ASKUE
MEMBER
Can this be fixed? Crack above the thermostat. Got too cold and froze.
Images (Click to enlarge)
May 1, 2017 at 1:37 PM
CARADIODOC
Experienced Mechanic
3.3L or 2.4L? The easiest is to just bolt on a new intake manifold, but my concern is if that froze, what about the rest of the block?
May 1, 2017 at 1:52 PM
TIMOTHY ASKUE
MEMBER
3.3, two of the lower freeze plugs popped off, but I fixed that. As far as I know the rest is fine.
May 1, 2017 at 1:58 PM
CARADIODOC
Bolt on an intake manifold, then if it holds coolant, you will likely have gotten lucky. Things could be worse.
May 1, 2017 at 2:50 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
