After replacing the water pump cannot get belt installed
202,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
KBEE
  • 9 POSTS
Hi, changed the water pump now cannot get the belt back on. The alternator has no tensioner.
Feb 27, 2020 at 2:49 AM
  • 110,248 POSTS
This vehicle isn't offered in the US, so I have very little technical info. Can you tell me if the belt is a serpentine belt or does the alternator have a separate belt?
If there is only one belt, it is routed correctly, and you have the correct belt, then the belt tensioner is most likely bad.
Check if the tensioner is moving correctly and it is strong.
Feb 27, 2020 at 7:46 AM
KBEE
  • 9 POSTS
It is a serpentine belt.
Feb 27, 2020 at 8:41 AM
  • 110,248 POSTS
Then I suspect it has an automatic belt tensioner. All 2010 Kia models do here in the US. Are you sure the belt is routed properly? If it is, then I suspect the belt tensioner is bad.
Here is a link that shows in general how one is replaced. Take a look through it.
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
Let me know what you find and if this helps.
Feb 27, 2020 at 9:49 AM
