Would excessive amount of oil lube. On the belts make my belt and sprocket slip off? however it still drives.
Apr 2, 2017 at 12:58 AM
HMAC300
✓Experienced Mechanic
yes oil on any belt makes it come off you have to stop the leak and fix this other wise you may send a valve into the piston causing major engine damage.
