Engine begins to shake after 30 seconds of start up?
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MAJZINGER KOPPáNY
I've got a problem with my vehicle listed above 2.0l Petrol. Basically, when I start it up from cold, I leave it for about 30 seconds and the engine starts to shake and the revs go up and down ever so slightly. If I try to accelerate it's like it's trying to pull away but can't and jolts a lot even with my foot all the way down. Once the shaking is done it runs fine and won't do it again unless I turn it off for a couple of hours and start it up again. Run an engine diagnostics test but nothing comes up. I really appreciate your help! Thanks!
Mar 9, 2023 at 5:41 PM
  • 55,588 POSTS
This sounds like a combination of the intake vacuum leak and the engine misfiring under load. Please check out this guide when the engine is cold to see if you get a reaction:
And if a tune up has not being done, I would go over this guide step by step:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Please do a throttle bore service as well.
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Mar 10, 2023 at 5:45 AM
