Engine bay fire question?
190,000 MILES
MIKEH93
I had an engine bay fire that I put out with a BNC fire extinguisher that left a chemical powder. It used primarily sodium bicarbonate.
I tried cleaning it out with canned air, general cleaner, a detail brush and cloth, but I haven’t gotten all of it.
Should I try to rinse the bay out with the hose? I would avoid the fuse box and other electrical components. Is it okay as is? I would say I got rid of 50% of the dust but the other 50% I can’t get my hands to. Thanks.
Jun 20, 2023 at 7:41 AM
  • 110,244 POSTS
You can use water but as you are aware, you don't want to get the electronics wet. Make sure they are covered.
Also, you may want to try blowing it out using a compressor and air gun. That way you could get much higher pressure.
Jun 20, 2023 at 3:49 PM
MIKEH93
Hey Joe,
I don't have access to this right now; I feel more comfortable doing this with air 100% however, I don't have the compressor.
Is it okay if it stays a bit dusty and caked in some areas for a few weeks while I find a compressor for a good deal?
Best,
Michael
Jun 21, 2023 at 4:17 AM
  • 110,244 POSTS
That is a tough question to answer without seeing or knowing to what extent it is caked and where it is. Could you take a couple of pics of what you are dealing with and upload them so I can see what you are facing?
joe
Jun 21, 2023 at 4:06 PM
