It could also be a broken valve spring. The valve may not be closing all the way and it backfires out that cylinder. I attached a picture of the valve spring for you. Once one of the coils break, the spring will not have enough pressure to hold the valve closed.
Image (Click to enlarge)
Jun 12, 2021 at 10:08 AM
39TB
MEMBER
Thank you Roy, I will do a compression test before I start pulling valve covers. Lee
