Hi Terri,
Nearly 40 years in the business and I have never seen a thermostat housing on the radiator. I have seen them at the bottom of the engine feeding off the lower radiator hose. However, your vehicle should have one at the end of the upper radiator hose (top of the engine). If you follow the upper radiator hose to the engine, it will end at the thermostat housing. If you look at pic 2, it shows what the housing looks like, As far as plastic or metal, both were used over the years, but that really shouldn't matter.
If you are replacing the thermostat, here is a link that explains in general how it is done. If it is a different problem you are fixing, let me know what it is.
Here are the directions for alldata. They are a bit vague. That is why I included the link above. The worst part of replacing it is you have to craw under the vehicle to open the drain on the radiator. You will need to drain the coolant just a little below the height of the thermostat; otherwise, it will leak from the engine when you remove the thermostat housing.
___________________________________________
1999 Ford Truck Explorer 4WD V6-4.0L VIN E
Procedures
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Procedures
PROCEDURES
Removal
CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
1. Partially drain the cooling system.
2. Remove the upper radiator hose.
pic 3
3. Remove the bolts.
pic 4
4. Remove the thermostat and gasket.
Installation
pic 5
1. Follow the removal procedure in reverse order.
______________________________________________
Let me know if this helps. Also, if you have questions or need help, please feel free to let me know. One last thing. the first and last pics below is an actual photo of the entire inlet assembly. I circled the thermostat housing portion. There are (I think) three bolts that hold it on to the unit. Under that is the thermostat. For some reason, it ended up being on there twice and I can't delete one of them. Sorry.
Images (Click to enlarge)
Dec 21, 2019 at 1:40 PM
