The car runs but will not shift with a mass airflow sensor plugged in?
280,000 MILES • 2.3L • 2WD • AUTOMATIC
MATTHEWHOOPER
If you unplug the mass airflow sensor the transmission will begin to shift again but the engine will then begin to bog.
Sep 15, 2023 at 10:15 AM
  • 110,248 POSTS
It sounds like the mass air flow sensor is faulty. Have you replaced it or tried cleaning it? If not, first, try to clean it.
Here is a link that explains how to do it:
https://www.2carpros.com/articles/mass-air-flow-service
If you do clean it, make sure to use a cleaner designed for the sensor. Also, if that doesn't resolve the issue, replace the sensor.
Sep 17, 2023 at 7:05 AM
MATTHEWHOOPER
We have the mass airflow sensor so idk what to do to it.
Sep 17, 2023 at 2:04 PM
  • 110,248 POSTS
Do you have the original one or a new one? Or do you mean you installed the new one and nothing has changed?
Let me know. Also, let me know if you have scanned the can-bus for diagnostic trouble codes.
Sep 18, 2023 at 6:04 AM
