Engine and TCS lights are on
2004 HONDA ODYSSEY
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATTHEW MCCOY
The engine light, as well as the TCS light comes on when I drive the car. The car runs fairly normal at idle and slower speeds but when I go past 50 MPH it starts to vibrate when I accelerate. Would this be a problem with the EGR valve or would it be something else?
Jan 10, 2021 at 6:34 AM
More then likely this is a wheel speed sensor issue. Here is a guide that will help with pulling codes as that is what we need to do to confirm this:
https://www.youtube.com/watch?v=rTtAnsOlZU4
Also, here is a guide that will help in testing the speed sensors but we need the codes to find out which wheel the issue is on:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Lastly, here is a guide that talks about what traction control is if you are interested in it:
https://youtu.be/K5AJVMk4U8Q
Let us know what codes are there and we can take next steps. Thanks
Jan 11, 2021 at 8:25 AM
