Engine and PCM wiring schematic?
103,500 MILES • 4.0L • V6 • 4WD • AUTOMATIC
FONTAINE
Thank you for the plans. I have to rewire the oxygen sensors because I have an error code P2195/P2197 and I noticed that the cables were all stripped at the connector and the probe cable goes into which PCM connector?
Dec 28, 2023 at 1:47 AM
  • 55,732 POSTS
Sure, here is a guide to help you test the connections and I have included the engine /PCM wiring diagrams which included the oxygen sensors.
Check out the images (below). Please upload pictures or videos of the problem so we can see what's going on.
Dec 28, 2023 at 3:42 AM
