Engine acting like it has vacuum leak but not the problem
156,783 MILES • 5.8L • V8 • 4WD • MANUAL
BAMF12
1985 ford with a 351 Windsor 5.8 liter not original engine was swapped from the original 302 and it ran fine for 4000 miles week ago turned truck off and then thirty minutes later went to start back up and would I looked at all the the vacuum lines and caps that are on the engine and also the blaster coil and wires from that and also we went from electronic to points on the engine. We got it running and still didn't act right when idling the engine up but got back to our garage and put new spark plugs and wires new distributor cap rotor rebuilt carb and put new vacuum lines and caps adjusted timing properly and true running it down the road back fires bad when throttling the truck up so we checked crossed wires double checked vacuum problems and truck still won't run right but also were running a newer 600 edelbrock on the 351 Windsor we tighten down head bolts and valve cover bolts replaced all the gaskets were just asking for other suggestion all rocker arms and rockers are moving right were thinking timing chain but really don't won't it to be that we still have to check compression on all the cylinders and check all ignition wires but were sorta stumped on why it just acted up after starting back up after running perfect and also have bigger cam shaft and newer heads cylinder rings just give us suggestions thanks diamond h farms Sean hunley
Jun 24, 2014 at 10:08 AM
  • 110,251 POSTS
You now have points and condenser rather than an electronic ignition?
Jun 24, 2014 at 12:46 PM
