While driving the engine, ABS and oil light turned on at the same time and the car shut off?
170,000 MILES
THANKYOUFORTHEHELP1
I was driving and the check engine, ABS and oil light can on at the same time, and nothing happens when I step on the brakes or gas. Then shut off and would turn on until I got a jump. I replaced the pass air flow about 3 weeks ago and check engine light went away but had come back on the day before this happened and I did notice it didn’t seem like I was using as much gas as I should for the distance I drove. It’s idling very rough. Also, I ran over a big hidden pothole that same even (don’t know if this is an important detail) but drove for a mile after no problem including stopping the car and restarting. So, I don’t think it’s that. Any help would be appreciated!
Jan 22, 2024 at 8:10 PM
BORIS K
  • 836 POSTS
You report that the vehicle cut out and would not start until you got a jump. Does this mean that the battery was discharged? Rough running could also indicate a low voltage situation. Also, you mention that you hit a pothole shortly before the vehicle cut out.
I would suggest checking the battery connections and the charging of the alternator.
Please see below links.
and
See video:
https://youtu.be/Z-p4dMJUpUw?si=DQCzu-tMsaBXXUZm
How to use a voltmeter:
Cheers, Boris
Jan 22, 2024 at 11:31 PM
THANKYOUFORTHEHELP1
Okay, thanks for the advice! And replying so fast :)
Jan 23, 2024 at 1:31 AM
BORIS K
  • 836 POSTS
Thank you for using 2CarPros.
Please let us know if you require any more assistance.
Cheers, Boris
Jan 23, 2024 at 7:31 PM
