engine management light comes on
2008 VOLKSWAGEN GOLF
140,000 MILES • 1.9L • TURBO • MANUAL
QADYY
I have a 58 plate VW Golf 1.9 TDI Match Bluemotion, and when i start the car, it takes a couple of seconds to start up and sometimes the engine management light comes on and stays on for a couple of hours and then goes off again and sometimes the glow-plugs light flashes with the traction control light on as well. Why does this happen? But even when these lights are on, the car runs fine. When starting the car up, whether warm or cold, it takes around five to ten second for it to to start
Jun 30, 2017 at 5:18 AM
SATURNTECH9
  • 30,869 POSTS
I need to get the exact code numbers not code descriptions you have could have a high pressure pump going out. The flashing glow plug light is a engine miss fire that is pretty bad.
Jun 30, 2017 at 6:33 AM
SATURNTECH9
  • 30,869 POSTS
Here is a link to how to get the trouble codes out of your car.
Jun 30, 2017 at 6:35 AM
QADYY
Sorry, i got confused about the glow plugs. when that comes on with the ESP, they do not flash, the amber light on the glow plug stays on from the ignition as well as the ESP.
Jun 30, 2017 at 6:49 AM
SATURNTECH9
  • 30,869 POSTS
Okay, I still need to start by getting the exact code numbers not code descriptions you have in the computer. That is the first thing I would do if I had the car in front of me.
Jun 30, 2017 at 8:10 AM
QADYY
The code is i got from the mechanic was P0340, Hope this helps
Jul 1, 2017 at 3:12 AM
SATURNTECH9
  • 30,869 POSTS
That should be for the camshaft position sensor.You can try using a multimeter to check the ohms reading of the camshaft position sensor.
Jul 2, 2017 at 1:12 PM
