Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Electrical
Ignition Switch
Key
engine only runs when the key is turned to the start position
1990 HONDA ACCORD
145,000 MILES • 2.2L • 4 CYL • 2WD
WESLEYWOODS.
MEMBER
1 POST
the car will start but when i release the ignition key the car cuts off, if i hold the key in the start position the car will continue to run.
Dec 27, 2016 at 1:29 AM
HMAC300
Experienced Mechanic
try resetting security system it may be messing up. if it does not help have a mechanic check for a bad ignition switch. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 27, 2016 at 1:30 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
