engine only runs when the key is turned to the start position
145,000 MILES • 2.2L • 4 CYL • 2WD
WESLEYWOODS.
the car will start but when i release the ignition key the car cuts off, if i hold the key in the start position the car will continue to run.
Dec 27, 2016 at 1:29 AM
HMAC300
  • 48,601 POSTS
try resetting security system it may be messing up. if it does not help have a mechanic check for a bad ignition switch. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 27, 2016 at 1:30 AM
