Are you sure it is the engine because my wife has this car, and the rear differential fluid was broken down and makes the car shutter. Check out this video:
Please upload videos in your response of any problems so we can see what to help you with.
Sep 7, 2024 at 11:35 AM
✓Experienced Mechanic
Yep, the fluid in the rear differential breaks down and does not allow the differential clutch discs to disengage which makes the "bumping" sensation. The differential only holds less than a quart of their special fluid. Each quart is $75.00 at the dealer, and you must use their fluid. How many miles are on it?
Sep 8, 2024 at 4:07 AM
We have seen the dealer replace the rear differential for $5,000.00 to fix this problem, so the fluid is a cheap fix. Please let me know what you find.
