engine compression
130,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
FORDSMB454
  • 42 POSTS
I conducted a compression test on my dad's vehicle listed above. I did each cylinder dry and wet test cylinder 2 read a 90 rest cylinders were at 175-185 dry did cylinder 2 wet with tiny bit of oil nothing changed. I assume the valves are broken or stuck i threw some air in the cylinder 2 with it being on almost compression stroke hear ait coming through the air intake i assume the intake valve is stuck or something? any help be great thanks any ideas?
May 10, 2022 at 6:51 AM
  • 110,248 POSTS
If the oil made no difference, then you are likely correct, it's related to a valve not seated fully or damaged.
I assume this test was done due to a misfire. Were there any other symptoms you noticed such as white smoke from the exhaust, or any overheating issues? It could be a head gasket issue, but that is a big difference in cylinders.
Take a look through this link and let me know if anything mirrors something you remember:
If not, the next thing to do would be to remove the valve covers and see if there is anything pointing to a stuck or damaged valve.
May 10, 2022 at 1:14 PM
FORDSMB454
  • 42 POSTS
Yes, kept throwing cylinder two misfire code truck was running rough and my dad said he would stall at redlights with A/C or he have to put the truck in neutral otherwise it stalls no smoke though no white smoke no sounds nothing taping nothing. just think it's the intake valve i think it may be bent or stuck.
May 10, 2022 at 1:47 PM
  • 110,248 POSTS
I would remove the valve cover on that side of the engine and see if there is anything indicating a problem with the intake valve. I say intake valve because you mentioned hearing the air come through the intake.
Let me know if I can help in any way.
May 10, 2022 at 2:00 PM
