security system reset?
270,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
RYPARKAVE
car wont start. Replaced ignition switch. Believe its the passkey 3 system in anti theft mode. But doors are still unlocked and accessory power works sometimes but wont completely turn off unless i disconnect battery. I am 3rd owner. Have no key fob and chip is not in key but in ignition lock cylinder i guess. Need to bypass or fix so car will start. Checked fuel and starter etc. Arced starter it ran for 3 seconds then shut off. Tested battery etc. Help please.
Mar 27, 2021 at 3:21 AM
  • 55,721 POSTS
If the security light is flashing you need to reset the system. this guide can help you fix it:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 29, 2021 at 1:50 AM
