Engine will not crank
98,000 MILES • 3.4L • 6 CYL
DARRELHYBERG
I replaced starter and ignition and fuel pump it won't crank with key.
Mar 12, 2021 at 5:32 AM
  • 110,246 POSTS
Have you checked fuses and the starter relay? If you look at pic 1, I highlighted the fuse and relay. Both are located in the under hood fuse/relay box.
Check the fuse first. Confirm there is power to it and from it. If it is good, switch the relay with a different one having the same part number.
Here are two links you may find helpful:
If the relay and fuse are both good, we need to check for power at the starter motor. Here is a link that explains how to perform the test:
Pics 2-5 show the power distribution schematics for the vehicle. I'm adding them in the event you need them. I did cut them in half to make them more readable. However, I did overlap them so you could follow them easier.
Take care and God Bless.
Mar 12, 2021 at 12:00 PM
