Engine swap?
110,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TGREEN05
Will a 2015 Kia Optima 2.4 GDI engine for a 2011 Hyundai Sonata 2.4 GDI?
Apr 27, 2023 at 10:58 AM
  • 110,248 POSTS
I'm not sure what you are asking. Do you mean with the two interchanges? If that is correct, the engine is the same, but things like sensors will need to be switched between the two engines.
Let me know if that is what you needed.
Apr 28, 2023 at 4:53 PM
