Replacement engine will not stay running?
140 MILES • 3.6L • 2WD • AUTOMATIC
KDESPRADEL93
Had engine replaced and car will only start when you disconnect and reconnect the battery and after a few minutes of being on it will cut off.
Jul 19, 2023 at 4:46 AM
  • 55,743 POSTS
So, these engines have a safety that if the engine oil pressure is too low to will cut the engine off, but it should leave code for it. please use this guide:
Please go over this guide and get back to us.
Jul 20, 2023 at 6:21 AM
KDESPRADEL93
It hesitate to cut on after you disconnect and reconnect the battery about 10 times before it actually cuts on and then after its running for a few minutes Its cuts off.
Jul 20, 2023 at 9:09 AM
  • 55,743 POSTS
Can you please run the codes and let me know what comes up?
Jul 22, 2023 at 1:48 AM
