Had engine replaced and car will only start when you disconnect and reconnect the battery and after a few minutes of being on it will cut off.
Jul 19, 2023 at 4:46 AM
✓Experienced Mechanic
So, these engines have a safety that if the engine oil pressure is too low to will cut the engine off, but it should leave code for it. please use this guide:
It hesitate to cut on after you disconnect and reconnect the battery about 10 times before it actually cuts on and then after its running for a few minutes Its cuts off.
Jul 20, 2023 at 9:09 AM
Can you please run the codes and let me know what comes up?
