Engine
136,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
JADE0213
Ticking noise coming from under the hood changed oil and filter after 15 min of idling oil pressure drops to zero and check gages light comes on. Someone one said it was a rod another person said it was head gaskets.. All other gases fine no overheating or anything else just things ticking noise that doesn't sound like knocking but ticking any suggestions?
Apr 15, 2016 at 12:17 PM
HMAC300
  • 48,601 POSTS
if oil pressure drops it's something in bottom end or a pump problem. the ticking may be due to low oil pressure. if it knocks have it looked at locally for a better diagnosis
Apr 15, 2016 at 11:16 PM
JADE0213
What is bottom end? Like I said no knocking just ticking.. Could it possibly be the oil sending unit..
Apr 16, 2016 at 12:42 PM
HMAC300
  • 48,601 POSTS
check oil pressure manually with a gauge or have it done. the bottom end of motor usually refers to rod/main bearings. the ticking may be coming from a bad lifter or low oil pressure or a rocker out of adjustment. that is why i said to have it checked locally.
Apr 17, 2016 at 1:32 AM
