The engine cranks but does not start, no pulse at coils?
180,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
PECAN
crank no start no pulse at coils.
May 16, 2024 at 2:17 PM
PECAN
getting no pulse at coils.
May 17, 2024 at 4:45 AM
  • 110,248 POSTS
The first thing I suggest is this. If you have a live data scan tool, see if there is an RPM signal when cranking. Or see if the tachometer moves at all when cranking. If there is no RPM signal, suspect a faulty crankshaft position sensor.
This sensor is located slightly behind and above the starter. I attached a pic below.
If that isn't the issue, we need to check for power. Each coil will have a red wire at connector pin 3. With the key in the run position, confirm there is battery voltage at those wires and let me know what you find.
May 17, 2024 at 1:30 PM
