Engine won't idle right and the won't accelerate?
150,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
GENE2424
The car won't idle right and the won't accelerate right the the code is misfire cylinder 1 I replaced plugs ,coils all 4 cylinders and injectors still remains still shows misfire on 1.a mechanic friend of mine He said its sounds like it needs to be flashed. I seen a video of yall doing a hard reboot on a vehicle take the negative side of battery and alligator clip positive to lost negative for 5 minutes for a factory reset do you think this would help me with a flash.
Dec 22, 2025 at 12:19 AM
  • 55,710 POSTS
I think the first thing to do is a compression test on cylinder #1, I don't think a hard reboot will help, here is a video to help you do the compression test, you can rent a gauge set at AutoZone for free.
https://www.youtube.com/watch?v=KOxIm1F8AW0
Please go over this guide and get back to us.
Dec 23, 2025 at 2:40 AM
GENE2424
I'm sorry I meant to say that I check compression on cylinder 1 was good.
Dec 23, 2025 at 8:04 AM
  • 55,710 POSTS
Okay, what was the reading? PSI=? You can try a hard reboot but it may not work, here is a video to show you how. It sounds like you have a vacuum leak so I included a video on how to check for that as well.
https://www.youtube.com/watch?v=INiDRO5A5MY&pp=0gcJCU0KAYcqIYzv
and
https://www.youtube.com/watch?v=LRKWV4Are5c
Also, can you please re-run the codes and list any that come up please? Please let us know what happens.
Dec 24, 2025 at 1:58 AM
