What happens and what are consequences when cooling liquid penetrate in combustion chambers from the intake manifold?
142,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
ABAYA
  • 77 POSTS
This happened just during engine rebuild in the workshop.
Thank you very much.
Mar 4, 2024 at 2:10 PM
BORIS K
  • 836 POSTS
As long as the engine was not started in general nothing happens if coolant leaks into the engine from the intake side. The best way to get rid of coolant in the combustion chambers is to either remove the injectors or glow plugs, then crank engine over until no more coolant is pushed out.
Cheers, Boris
Mar 4, 2024 at 11:05 PM
ABAYA
  • 77 POSTS
Thank you Mr. Boris.
Mar 4, 2024 at 11:57 PM
