This happened just during engine rebuild in the workshop.
Thank you very much.
Mar 4, 2024 at 2:10 PM
BORIS K
✓Experienced Mechanic
As long as the engine was not started in general nothing happens if coolant leaks into the engine from the intake side. The best way to get rid of coolant in the combustion chambers is to either remove the injectors or glow plugs, then crank engine over until no more coolant is pushed out.
Cheers, Boris
Mar 4, 2024 at 11:05 PM
ABAYA
MEMBER
Thank you Mr. Boris.
Mar 4, 2024 at 11:57 PM
