Engine misfire
104,000 MILES • 1.2L • MANUAL
MIKE BENNETT2
I was having a cylinder misfire and are being told that I need a new engine or an overhaul due to low compression. is this true and what is the average price? as I have been told $3,000.00.
Oct 24, 2017 at 2:02 AM
  • 31,937 POSTS
Before commenting any further i would like to know what the compression readings are and i would like the readings done wet and dry, if your mechanic dose not under stand that, i would be looking for a mechanic that does as this is important in determining the cause of any low compression problem.
Oct 25, 2017 at 9:16 AM
