Check engine light on
2000 ISUZU
295,000 MILES
HECTORVK
My KB 320 v6 is showing a warning check engine light, but was serviced last month. I have check oil, water and fan everything seems okay.
Thank you
Jul 11, 2017 at 5:52 PM
CARADIODOC
  • 34,415 POSTS
That light has nothing to do with fluids. Your engine computer can detect over 2,000 different problems. When it does, it sets a diagnostic fault code, then if that problem could adversely affect emissions, it turns on the check engine light. The place to start is by having the fault codes read and recorded. They will indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. The people at many auto parts stores will read those codes for you for free.
Jul 11, 2017 at 6:20 PM
