Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Accent
Warning Lights
Check Engine Light
Car shakes and engine light came on
2010 HYUNDAI ACCENT
12,000 MILES • 4 CYL • AUTOMATIC
LEELEE1954
MEMBER
1 POST
Car was working fine until engine light went on. Now it is shaking as if it wants to turn off and has no speed.
Aug 3, 2018 at 6:30 AM
Experienced Mechanic
Good afternoon.
From your description, it sounds like you have an engine miss.
I would start with a compression test and also inspect the plugs for wear.
When was the last time you had a good old fashion tune up?
Aug 3, 2018 at 7:09 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
