car will not start and it is throwing off code the code 3, 4, 7?
161,000 MILES • 2WD • AUTOMATIC
COLIE
Got my timing chain fixed new battery alternator purge valve and oil change
almost 2 weeks ago and now my car won't start and it's throwing off code the code 3,4,7 and it says crankshaft sensor a and b.
Feb 19, 2024 at 6:21 AM
  • 110,248 POSTS
Do you mean the code is P0347? Let me know that, but also, I want you to check something.
First, see if the engine starts if you use starting fluid. If it does and then stalls, we will know it is a fuel-related issue. I'm suggesting this because the P0347 is related to a camshaft position.
If there is no change with starting fluid, I need you to check if there is spark at the plugs. If the problem is a faulty crankshaft position sensor, chances are there will not be an ignition spark at the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Feb 19, 2024 at 1:05 PM
COLIE
The car doesn't start at all those are all different codes.
Feb 19, 2024 at 2:00 PM
  • 110,248 POSTS
Diagnostic trouble codes are a letter followed by four numbers. Most powertrain codes start with the letter P. I'm not sure what the individual numbers you listed indicate. Individually, they are not diagnostic codes.
As far as the no start, does the starter motor turn the engine but it doesn't run or is it the starter isn't engaging? If the starter is turning the engine, check to see if it will start with starting fluid. If it doesn't, I need to know if there is an ignition spark to the plugs.
Let me know. Also, if the starter is turning the engine, if possible, record the engine turning and upload it for me to hear.
Feb 20, 2024 at 10:49 AM
