No oil underneath drives well. has new not no exhaust smoke, but on top of engine get oil that burns off once engine is at temperature.
Jun 8, 2020 at 11:21 PM
✓Experienced Mechanic
Can you get a picture of where you are seeing oil getting burned off? More then likely you have a leak towards the top of the engine like a valve cover.
If you can get a picture that would help. Otherwise, we need to clean the engine with a spray cleaner to clean off the oil and then look each day to find where it is coming from.
