Top of the engine gets oil that burns off
84,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
ZIMBAB
No oil underneath drives well. has new not no exhaust smoke, but on top of engine get oil that burns off once engine is at temperature.
Jun 8, 2020 at 11:21 PM
Can you get a picture of where you are seeing oil getting burned off? More then likely you have a leak towards the top of the engine like a valve cover.
If you can get a picture that would help. Otherwise, we need to clean the engine with a spray cleaner to clean off the oil and then look each day to find where it is coming from.
https://www.2carpros.com/articles/engine-is-leaking-oil
Let me know and we can go from there. Thanks
Jun 9, 2020 at 1:51 AM
