Fluctuating rpms
70,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TOMMY THOMAS
When the motor is in idle, transmission in park, and the motor cold, is the motor suppose to speed up and slow down, back and forth, when gas is applied? When motor warms up it stops. Is this normal?
Feb 24, 2018 at 12:33 AM
Good morning
No, it is not normal at all. It should stay nice and smooth.
Is the check engine light on?
When was it last serviced?
Feb 24, 2018 at 12:51 AM
TOMMY THOMAS
Yes, the engine light is on. I put my code reader on it, and it indicated a low vacuum leak. Could this be the cause? Could that be it or could I just need a fuel cap replacement?
Feb 24, 2018 at 1:39 AM
What is the code number?
A vacuum leak will definitely cause this issue.
Feb 24, 2018 at 1:41 AM
