Engine not separating from engine for replacement
110,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KOBEFLOYD35
Why won’t the transmission come loose off the engine? I’ve took out the torque converter bolts and bell-housing bolts.
Feb 5, 2019 at 12:33 AM
Good morning,
A lot of times the dowels that keep the transmission and the engine aligned get crud on them. You may need to use a screwdriver to separate them from the dowels.
Feb 5, 2019 at 1:17 AM
