Engine
157,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MTAYLOR233
I was driving home from work and going down the road with my foot on the gas and it lost throttle power then the engine started shaking. I made it to the next stop sign and it died. The engine started, but with a very violent shake. It died again and had to be pushed the rest the way home. Now the car won't stay running unless you keep your foot on the gas. No lights on the dash board came on and the engine shakes bad.
Mar 2, 2016 at 1:21 AM
MTAYLOR233
The coolant light does flicker on and off, could it be the water pump?
Mar 2, 2016 at 2:03 AM
  • 31,937 POSTS
run a scan anyway as not all faults will set a check light, also check fuel pressure and check for a blocked fuel filter, start here.
Mar 2, 2016 at 4:37 AM
