Engine is hard starting
300,000 MILES • 2.3L • 5 CYL • 2WD • MANUAL
CHAD WARSHIP
Engine rough starting and hunting when idling, and it struggles to pick up rev from low down.
Jan 13, 2021 at 2:29 AM
More then likely this is a vacuum leak. Here is a guide that will help with figuring this out for sure:
If there is no vacuum leak then we need to monitor the fuel pressure and find out if that is correct as well.
I suspect this is an air issue which is why we lead with a vacuum leak but if both of these check out then we will need to know if there are codes.
If there are no codes then we need to move onto a possible mass air flow issue but we can get to that once we get through all this. Thanks
Jan 14, 2021 at 9:00 AM
