Engine not running properly
200,000 MILES
RICHARD GRAVENELL
Had a new fan fitted now the engine is not running properly. this was done in a local garage.
Jun 27, 2021 at 1:26 AM
  • 55,743 POSTS
Misfire? stall? please give us more details on what is going on. This guide may help:
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jun 28, 2021 at 2:13 AM
RICHARD GRAVENELL
Well, it all started with oil leak taken it to garage they said it was cam seal so had all the seals done.new cam and all new belts , took the van out for hour still oil everywhere, sent it back they said it sorted now but fan doesn't work they put new fan in. I took van out again and it’s misfiring, smoking, overheating and running very bad.
Jun 28, 2021 at 3:59 AM
  • 55,743 POSTS
Did the engine overheat before the repair if so you can have a blown head gasket. To be sure this guide can help us confirm the issue:
Jun 28, 2021 at 10:15 AM
RICHARD GRAVENELL
No after. Doesn’t lose any fluids.
Jun 28, 2021 at 2:43 PM
  • 55,743 POSTS
Okay, let's check the compression to make sure the engine is okay. This guide can help:
Jun 29, 2021 at 2:02 AM
