Engine
203,738 MILES • V6 • 2WD • AUTOMATIC
FERGUSON82
My car cuts off and smokes after it reaches the normal temp. It runs good when it's ran cold. Once the car warms up it cuts off and when I finally do get it started I have to keep my foot on the gas pedal even when I'm at a stop light using the brakes and it will only take me about a mile before it starts to act up
Apr 13, 2016 at 9:56 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Apr 13, 2016 at 10:56 PM
FERGUSON82
So what is the pressure suppose to be
Apr 13, 2016 at 11:55 PM
HMAC300
  • 48,601 POSTS
43 psi key on or idle. you ma need an adapter if no connection at fuel rail
Apr 14, 2016 at 2:28 AM
