With the car being in reduced power mode there must be an engine fault. Is the check engine light on? The first thing is to have any stored engine codes scanned. If you don't have access to a scanner or code reader most auto parts stores have a tool loaner program and can rent you one. Here is a tutorial showing what is involved:
Once you have the code or codes read get back to us with the code information and we can then properly diagnose. Hope this helps and thanks for using 2CarPros.
Nov 3, 2020 at 6:00 AM
✓Experienced Mechanic
There are a number of things we need to start with. Here is a guide that explains the basics:
