Engine PCM throws code P0335?
143,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
ABAYA
  • 77 POSTS
After i changed a new CKP, the engine refuses to start. And the PCM throws DTC P0335.
Please, how can I resolve this problem? Thank you.
Mar 9, 2024 at 11:15 PM
  • 110,248 POSTS
This model isn't offered in the US, but I will try my best to help.
The code indicates there is no signal from the crankshaft position sensor. As a result, there is likely no ignition spark at the spark plugs.
When you installed the sensor, did you have to shim it? That can create issues if the sensor is too far away from the toner wheel.
Mar 10, 2024 at 1:34 PM
ABAYA
  • 77 POSTS
Hi Joe,
Yes, before I installed the CKP in his place, the shimming was perfect.
Mar 10, 2024 at 4:02 PM
  • 110,248 POSTS
Okay, check to confirm there is spark to the plugs. Also, and I'm not sure why, the only thing I found for this year Captiva is a 2.4L (Mexico). I'm not sure where you are located.
I checked the code, and it is a crankshaft position sensor code, but the repair, according to Alldata, is the VVT solenoid, which doesn't make sense to me. See pic below.
Check to see if there is spark at the plugs. If there aren't, we need to confirm there are no damaged wires to the CKP or something that was pinched.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
See pic below.
Mar 11, 2024 at 11:23 AM
ABAYA
  • 77 POSTS
Thank you very much Mr. Joe.
Mar 11, 2024 at 2:17 PM
  • 110,248 POSTS
You are very welcome. Let me know what you find or if you have other questions.
Mar 12, 2024 at 11:59 AM
