Engine oil grade
5,000 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
CHUCKY CHI
What would be the right grade engine oil for the car listed above operating in temperatures of 19-35 degrees Celsius?
Jun 30, 2019 at 11:40 PM
Hi Chucky,
Looks like your engine calls for a 5W-30. This will also operate just fine in your temperature range.
Here is a guide that will help with changing the oil on this vehicle.
This is just a general guideline on how to do it so it is not going to look the same as your vehicle but the process is the same.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Below you will find the process from the manual on a similar engine. We don't have a manual on this exact engine but this is going to look very similar to your vehicle.
Please let me know if you need anything else. Thanks
Jul 1, 2019 at 11:43 AM
