Engine stalled, codes P0171, P0102, C1230 and C1229?
163,325 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
WARREN1814
  • 221 POSTS
Hello, there guys, it's just me Warren again. I have a question(s). Not too long ago (yesterday) i had my check engine light to come on. The following code is what my scanner found. First the familiar codes P0171 and P0102. I know the P0102 is the MAF sensor. We replaced that yesterday. And now these codes have shown up C1230 rear center input, C1229 rear speed sensor center coherency. On top of that i drove the van today and it ran really good. so far, the codes haven't come back on but as soon as i got home and pulled up in my driveway the van stalled on me. Now that is the first time i have ever seen it do that to me. But it did let me start it back up and pull it on up in the drive and to park it. Any ideas what is going on this time?
Aug 1, 2023 at 4:06 AM
  • 55,721 POSTS
Yes, this can happen when the fuel pump or the PCM power relay is going out. I would do a fuel pressure test to see if it is low, which will help us find the problem.
30 to 45 psi - you can rent a fuel pressure gauge from the auto parts store for cheap or free.
P0171 - System Too Lean (Bank 1):
P0102 - Mass or Volume Air Flow Circuit Low Input:
These codes are a separate problem, we only handle one problem per thread, please post your new question here, you must be logged in.
C1230 - Right Rear Wheel Speed Sensor Input Signal Missing:
C1229 - Right Front Wheel Speed Sensor Input Signal Missing:.
Here is the PCM power relay and fuel pump relay you can swap out which can fix the problem. Check out the images (below). Please let us know how it goes
Aug 1, 2023 at 7:45 AM
WARREN1814
  • 221 POSTS
Hello there Ken. Thank you for taking the time to reply. And okay, then i will make another thread dealing with the P0171 and P0102. Far as the ABS sensor goes i will call this new shop that moved in down the street from me and see how much they will charge to fix my ABS speed sensor problem (and thank you for telling me which ones the codes refer to because the scanner i have doesn't). Also, I will let you know what they have to say about it and what they will charge me to fix it. Also, i will have to have someone to see if they can reach the fuel pump relays you talked to about because i am in a wheelchair and i can't reach those unfortunately, Thanks again for sharing those diagrams. They're always a big help!!! :-)
Aug 1, 2023 at 1:58 PM
WARREN1814
  • 221 POSTS
Hello Ken, well i decided to take the van out for a trial run and i went at least 24 miles. And the ABS light came on of course but the Check Engine Light didn't. I am confused as to what is happening but, keep in mind i did replace the MAF sensor 2 days ago. Also, i do remember running the A/C the last time i was in it. But i didn't run it this time. Do you think that not running the A/C this time had something to do with it? I know that is a stupid question but i had to ask it. Aug 2nd, 2023 time:11:53 am. So far i haven't found anybody to help me with swapping out the PCM power relay and fuel pump relay etc.
Aug 2, 2023 at 2:53 AM
  • 55,721 POSTS
I don't think the A/C had anything to do with it unless it is overheating? Let me know what happens with the relays.
Aug 2, 2023 at 11:56 AM
WARREN1814
  • 221 POSTS
Okay, I will. And no, it doesn't overheat at all, praise the Lord.
Aug 2, 2023 at 2:00 PM
WARREN1814
  • 221 POSTS
Oh, i forgot to ask. What is supposed to happen when i swap the relays? Just asking.
Aug 3, 2023 at 3:01 AM
  • 55,721 POSTS
It should fix the stalling problem, I hope.
Aug 4, 2023 at 3:03 AM
WARREN1814
  • 221 POSTS
Me too... Say, if i can find a store that has the ones i have... Would it be a good idea to replace them both with new ones?
Aug 4, 2023 at 2:22 PM
  • 55,721 POSTS
I would give it a try.
Aug 5, 2023 at 3:20 AM
WARREN1814
  • 221 POSTS
Just so you know, so far it hasn't stalled (and it starts right up too) on me since we replaced the MAF sensor. and no, i haven't swapped out the relays yet. But i will buy some anyway because here they're only $8.00 - $21.00.
Aug 6, 2023 at 8:07 AM
  • 55,721 POSTS
Thanks for letting us know, we are here to help.
Aug 7, 2023 at 3:33 AM
WARREN1814
  • 221 POSTS
You're welcome. and thank you for helping me once again. I am supposed to get my van's speed senor fixed tomorrow i will let you know what they had to say and how much it will cost me to get fixed.
Aug 7, 2023 at 9:15 AM
  • 55,721 POSTS
Sounds good, please do.
Aug 8, 2023 at 3:20 AM
WARREN1814
  • 221 POSTS
I will... but i do have another question for you. and it has to do with the C1230. You said this about the C1230, Right Rear Wheel Speed Sensor Input Signal Missing:
This code pertains to the ABS (Anti-Lock Brake System) and indicates that the system is not receiving a signal from the right rear wheel speed sensor. It could be due to a damaged or disconnected sensor, faulty wiring, or a problem with the ABS module.
But when i allow my scanner to scan that code it keeps saying C1229 rear speed sensor center coherency. What does it mean when it says center coherency? That makes me think it is talking about the center differential and not the back right wheel. Is my scanner off or what?
Aug 8, 2023 at 4:40 AM
  • 55,721 POSTS
Did you replace the sensor? If so, it could be the wheel bearing is starting to fail and it will allow the sensor not to be centered on the reluctor wheel. Can you please raise the rear of the car and grasp the wheel to apply pressure to the top and bottom of the wheel to see if it has play?
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please go over this guide and get back to us.
Aug 10, 2023 at 2:40 AM
WARREN1814
  • 221 POSTS
Hello there. No let me explain, so far, the sensor has not been replaced yet they are supposed to do that tomorrow for sure. That is what the guy said at the repair shop. We have been waiting for the part to come in. Here is what's happening at the moment. I have taken my van to AutoZone and O'Reilly's to let them use their scanners on my van to see what code it has in there. But AutoZone's scanner will not even read my van's computer. I have been to that store countless times (both stores) and it has but now it won't. It will allow them to input the information what is needed to get started but it won't do anything else. The guy at AutoZone let me see what was on the scanner at the time and it didn't pull up a thing. So, he said take it down to O'Reilly's and see if their scanner could pull up something (and they do not like sending their customers to O'Reilly's too). And their scanner worked but the guy said he didn't see any trouble codes of any kind. And he didn't see any codes related to the ABS. But the scanner you guys ask me to get for myself keeps finding the code C1230 and that's it. The ABS light doesn't stay on all the time it will just come on for a few mins and then go off.
Well, i can't lift the back of the van up and do that (wheelchair). I don't have a working jack either unfortunately. I sure wished i could believe me. I would have the sensor replaced a week ago etc., but i will see if i can get them to check it for me if this new sensor doesn't fix the problem. Can a bad sensor cause a person's brakes to act like that? When driving along if i push on the brakes slowly then i have breaks. But if i where to slam really hard on the breaks then i can hear this spring sound for a few seconds and the van tries its best to stop quickly but it can't seem to do it. But it will stop but not quick like when the ABS system is working.
Aug 10, 2023 at 6:07 AM
  • 55,721 POSTS
It sounds like the ABS is kicking in which a bad wheel speed sensor can cause, let's see if the new sensor fixes the problem which it should, please let me know what happens.
Aug 11, 2023 at 3:06 AM
WARREN1814
  • 221 POSTS
Update: I picked up the van and was headed home and what did I see?? The ABS light still on. Instead of going off and on. Now it seems to want to stay on. But, the funny thing is I have full brakes. Here is what the repair guy told me he did. Replaced the rear speed sensor of course. And he said I was low on gear oil. So he put some more gear oil in there for me as well. Total of repair was $121.56.
Parts: $43.00
Labor: $50.00
Shop supplies:$12.00
HazMat: $10.00
Tax: $5.58
He had my van from 9:15am – 3:58pm
And I don’t know what ABS codes are on there now I will check on it tomorrow. So far i haven't cleared the codes yet.. Should i go ahead and clear the codes or see what they are? I have no idea what's on there now. the last time i check only one code was on there and that was C1230 etc.
Aug 11, 2023 at 1:56 PM
  • 55,721 POSTS
I would clear the codes and drive it to see what happens.
Aug 12, 2023 at 3:06 AM
WARREN1814
  • 221 POSTS
Okay, i will. i have a strange feeling it may not take long for the ABS light to come back on though. I hope not but, we'll see...
Aug 12, 2023 at 1:46 PM
  • 55,721 POSTS
Please let me know.
Aug 14, 2023 at 4:24 AM
WARREN1814
  • 221 POSTS
I sure will. I need to pick up some supplies so i will let you know what happens etc. just a FYI here: the last code that was on there before i just erased it was C1229 the C1230 went away after the center speed sensor has been replaced. But as of now all ABS codes have been erased. Also, i was reading my scanner's manual i read in there where it said the following. "Permanent codes are a special type of confirmed code that only the vehicle can erase." I didn't know that. I thought that all scanners could erase codes.
Aug 15, 2023 at 11:59 AM
  • 55,721 POSTS
The system is self-correcting for some codes. Please let me know what happens.
Aug 16, 2023 at 4:46 AM
WARREN1814
  • 221 POSTS
Oh, oh okay. Well, here is the update: i went to the store and church etc. While driving along the ABS light came back on. Came home and put the scanner on it and both error codes came back C1230 and C1229. At first it was just the C1229 but now both have come back. Someone i know said it could be i just may need some new brake shoes all around. Since i haven't had them changed in 3 years etc. The thing that gets me still is when you hit the brakes it feels as though you have brakes. But it sure feels weird when you hit the brakes. Like something isn't correct etc.
Aug 16, 2023 at 12:02 PM
WARREN1814
  • 221 POSTS
Oh, just so you know... I think the repair shop just replaced the speed sensor in the differential. There is no way of me know as to i dropped my vehicle off and left it there and came back and they said they fixed it. I do not like doing that but when you have family members that do not like sitting around and waiting for their cars to get repaired and just want to drop it off and leave it. It's impossible to see if anything was repaired or not. Anyway, sorry i was doing a little venting, lol. But i have no idea if they changed any speed sensors in the front right or front left wheels in the van or not. And when you go to the parts store asking about parts, they only seem to sell speed sensors for the front left or the front right or the in the differential. I have yet seen one for the rear wheels (left or right) of my van that has drum brakes (Front has disc brakes). So, i must ask this silly question. Where are all the speeds sensors located at on a 2000 ford e-150 econ van located? If you don't mind me asking :-)
Aug 16, 2023 at 3:58 PM
  • 55,721 POSTS
Yes, on this van there are three wheel speed sensors, one on each front wheel and one for the differential which is for the rear wheels.
Aug 17, 2023 at 4:26 AM
WARREN1814
  • 221 POSTS
Oh, oh okay, sure glad you know where they are located :-) Did you see my update post? in a nutshell both codes are back C1229 and C1290 is all. Do you think it may be due to the brake pads my need to be replaced? Just asking...
Aug 17, 2023 at 6:12 AM
WARREN1814
  • 221 POSTS
Thank you for letting me know where the speed sensors are located. I wouldn't have ever found out where they were with the scanner i have.
Aug 18, 2023 at 2:30 AM
  • 55,721 POSTS
Lets start a new thread for the C1229 and C1290 codes please.
Aug 19, 2023 at 1:59 AM
WARREN1814
  • 221 POSTS
Okay..
Aug 19, 2023 at 2:40 AM
