engine won't even turn over! What do you think?
210,000 MILES • 4 CYL • 2WD • AUTOMATIC
6PAC-MAN
  • 5 POSTS
Speedometer works off/on, tachometer will fluctuate when speedometer isn't working. Suspect speed sensor. Had transmission rebuilt couple months ago and that works perfectly!
So, i went on this site and one rep. said to remove both battery leads, touch them together to drain any static volts. I did this and reconnected battery. now engine won't even turn over! What do you think? Randy
May 13, 2019 at 1:42 AM
SCGRANTURISMO
  • 4,897 POSTS
Double check the battery connections for me and make sure sure they are clean and tight. Then could you take a voltage reading for me with a multimeter, please. If you are unfamiliar with how to use one I have included a link below for you to go to.
Please go through this guide, if necessary, and get back to us with what you find out please.
Thanks,
Alex
2CarPros
Jun 25, 2021 at 5:15 AM
6PAC-MAN
  • 5 POSTS
Battery vdc=12.51, it is a new battery & works fine. Dash lights come on. @ other points of interest-----1. car was sitting for a # of years. I just recently got it back on the road & insured. trans. was completely rebuilt & works great. The speed sensor started a few weeks ago & the no crank happened >I removed battery cables & touched them, as was mentioned. 2. There has been times when i'd go to start eng. & nothing would happen. I'd turn key Off, then try to start again & it'd crank right up! It always starts quickly--never has to turn over a lot to start! Engine runs strong, all lubs good, and is very reliable-----except now!!!
Randy
Jun 25, 2021 at 5:16 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
This could be a couple of things. It could be either your ignition switch or your neutral safety switch that is causing your intermittent no start condition. So let's start with the ignition switch. In the diagrams down below I have included the starting circuit wiring diagram and the diagnostic troubleshooting guide for the ignition switch in the diagrams down below. Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
6PAC-MAN
  • 5 POSTS
Well, i replaced the s/w a few yrs. ago because of mech. issue w/it. I keep going back to the fact the engine did start Always, but now > touching those battery cables together (off the battery), it won't crank at all! There Must be something (electrical?) that didn't reboot or charge up or?? > reconnecting the battery! The neutral s/w worked just fine also > trans. rebuild,----plus car Should start in Park, shouldn't it, even if neutral s/w Was bad. It always gets started in Park!
Randy
  • 55,770 POSTS
It sounds like the starter has gone bad but to be sure lets run down this guide
6PAC-MAN
  • 5 POSTS
Okay, as soon as i read about the alarm system, that i thought is the culprit and it was! Now I want you guys to know i really appreciate your help in fixing this issue. but, i may still have the Speed Sensor problem. I won't know until i drive car a bit. Now, looking back from my first email where i mentioned what was listed to do; remove and replace battery cables, touching leads, the information about "alarm system". Should have been included in the statement! I was pretty sure (or at least hoping), it was something simple, since everything on car worked just fine, with exception of speed sensor and none crank at initial try Sometimes. So, with all that said, I again thank you all for your help and will get back in touch. driving car around to see if speed sensor/speedometer/tachometer, is working full time or intermittently. Randy in Fla.
  • 55,770 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
